nervagon
- Joined
- Nov 18, 2020
- Messages
- 555
Oh it has that thick grease huh..
I would be very unhappy about that drag and would want to convert it to an ATF bath immediately.
Because it has removable internals, there's a very small area on the hub where you could have ATF hanging out. Tilt the bike a few degrees and that ATF is coming out of the side seals so now you need to figure out how to make that not happen and make ATF spillage only happen out the axles which should be minor.
ATF would improve the efficiency and durability of the drive. We don't know by how much.
It's another science experiment to throw money into and i'm starting to get exhausted with this effort already.
My semi recumbent will do 37mph on 1200W and has two gearing stages so i have more than enough room to regear.
I'm trading gearing problems for mounting problems but i think those would be easier to cure with the lowest amount of compromises. I think that's the better route to go.
I've sent an email asking bikee if there are any other possible options. I'm not crossing my fingers.
I still maintain that a compound chainring is your only practical option on the 26er. And you can test that without Bikee's involvement. Just disable the torque sensor and take it for a throttle only test ride with a 50/36 chainring setup. That should work with the existing firmware.
