Lights keep flashing
CatfishMan
So I have a TSDZ2 motor with Jumbo Shark 17ah EM3EV battery and 850c display. Motor and display are flashed with the custom firmware. I have everything working but can't get the lights to stop flashing. The headlight is a Roxim K1145 from Eco Cycles. I have it wired and connected through a speed sensor Y adapter. Someone in another thread mentioned maybe a wattage issue? I'm not even sure how to check that.
If it's flashing, and it's connected to your speed sensor, maybe the speed sensor pulses are causing it to flash?
Perhaps instead use just a regular steady voltage source for it, that is designed to handle the current draw that particular headlight pulls in operation?
