tvsinesperanto
- Joined
- Feb 3, 2009
- Messages
- 2
First post. Hi All.
Just wondering if anyone can fill in some of the gaps in my knowledge when it comes to LiPo batteries. I've heard good things about their energy density, recharge rates, and open circuit charge retention but I also know that they are a bit fiddly when it comes to management and charging. I'm hoping that someone here will be able to assist me with info about exactly what these batteries require for good maintenance and use.
I am in the process of building my first prototype EV (bicycle based for starters) and, since I expect to go through several iterations before I get something that I'm happy with, I'm trying to keep my costs down as much as possible with this first attempt. Obviously using a cheaper battery chemistry like Pb acid would do that for me quite effectively but there are good reasons why I need to use something with a much higher energy density (I won't bore you with why unless someone is interested). I'm hoping that I can significantly reduce my costs by building my own LiPo charger/BMS (I have a background in Engineering (Electronic and Mechanical) so I'm fairly confident that I can manage it), but first I need to find out exactly what these batteries require, how the commercial chargers work, and what sort of balancing circuitry or management systems are required.
The following is what I *think* I know about LiPos (picked up from what I've read on Wikipedia, various web sites, and just plain old deduction from looking at pics of LiPo packs). I'm hoping that people can take a look at what I have here and add to it where I am correct and correct me where I have it wrong...
1) LiPo cells operate at a maximum voltage of 4.23V and a minimum of 3.0V but are nominally 3.7V. Exceeding 4.235V or going below 3.0V may cause damage to the cell or cause fire/explosion. For this reason, any charger must monitor the voltage on each cell in the pack to ensure that they do not over-volt. Likewise, during discharge (use), the speed controller? (on-board BMS?) needs to have an under-volt cutoff.
2) Like other types of battery packs, LiPo packs have a single pair of high current (thick) wires that are connected across the entire pack (i.e. the red wire is connected to the positive terminal of the last cell and the black wire is attached to the negative terminal of the first cell).
3) However, unlike other types of battery packs, in addition to the high current wires, LiPo packs also have a number of low current (thin) wires equal to the number of cells in the pack minus 1 (eg. if a pack has 6 cells then there will be 5 thin wires in addition to the 2 thick wires mentioned in 2 above. Each of these wires is attached to each individual cell in the pack (Eg. Thin wire #1 and the black thick wire are across cell #1, thin wire #2 and thin wire #1 are across cell 2, etc., etc. right up until the thick red wire and the last thin wire which are across the final cell).
4) The individual taps (i.e. the thin wires) are not connected with a common ground (with the possible exception of those wired in parallel - confirmation required). Each tap wire is at a nominal potential of 3.7V higher than the previous one.
5) When under charge, the charger supplies the bulk of the recharge current via the thick wires and then, after reaching a pre-determined % of full charge, the charger stops supplying this bulk current and trickle charges each cell individually via the thin wire taps.
6) During discharge (i.e. while in use), the current runs to the load via the thick wires only. The thin wires are not connected to anything except when being recharged.
7) A LiPo charger is a fairly complex beast since it has to contain a number of different chargers in one unit. Firstly, it needs to contain a bulk charger that supplies the bulk of the charge (high current at the same voltage as the entire pack - Eg. 24V). Secondly, it needs to contain a whole series of low voltage, low current chargers that trickle charge each individual cell via the thin wires. The charger unit has to contain one of these for every cell in the pack that it is designed to charge. No wonder they are expensive.
That's about as much as I've been able to gather to date. However, even with the stuff I think I know, there are gaps. For example...
1) Do LiPo packs contain any sort of BMS or balancing circuit on the pack itself to ensure that the cells discharge uniformly? If so, what does this circuit look like and how does it work? Alternatively, if it doesn't, how do you ensure that the cells don't drop below 3.0V? Are there special speed controllers for use with LiPo batteries?
2) Assuming I am correct in assuming that LiPo chargers use a 2-stage charge sequence (a bulk charge to the entire pack followed by trickle charge to each cell), what currents are used in each stage? What is the nominal charge current for LiPo cells? Would it be something like 2A during bulk charging and 200mA during trickle? More? Less? I'm having a hard time finding this stuff out.
3) I imagine that most LiPo packs contain cells both in series and parallel. In these cases, do the packs have a tap off each individual cell or do they only have 1 tap at each common point in series (i.e. if it's a 6s2p pack, will there be only be 5 thin wires (1 between each cell in series) or will there be 10 (1 for each cell)?
4) What method do the chargers use to ascertain the charge level of each cell or pack? Do they just monitor the voltage or do they take into consideration other factors?
5) Again, assuming I am correct about the 2-stage charge process, what % of full charge is achieved via bulk charging before switching to trickle charging each cell? How is it measured (voltage level?)?
6) How do the chargers monitor the capacity of the pack as it ages? Again, does it just monitor the voltage or does it use other parameters like internal resistance? Does it even bother monitoring it at all?
I have a lot more that I want to ask but, for now at least, I'll leave it there. Any and all help will be greatly appreciated.
Cheers,
TV
EDIT: I've just read this excellent post http://endless-sphere.com/forums/viewtopic.php?f=14&t=2498 and it answered some of my questions (I did search before posting but didn't associate the term A123 with LiPo batteries - I'd never heard of them before) but there is still a fair bit I'm unclear on.
Cheers,
TV
