Eujangles
Hi All,
My goal with my next build is to be quite a bit more light weight than my super heavy last one. As such, I'm going the geared hub route (probably a MAC or an eZee), and despite my hesitation (due to my complete inexperience) would like to have a go at assembling a lipo pack...no matter what way I look at it, I'm not really getting any lighter while retaining a good top speed without it.
I have read the Wiki on building lipo packs as well as searching the forum, so please forgive me if the answers to my questions are available elsewhere here as I couldn't find them, and thanks in advance to anyone who can help.
1. Since it's very dangerous to discharge the cells below 3.0v, is it possible to have an automatic low voltage cutoff, or would I have to monitor the pack during rides with a CA or something?
2. I'm a bit confused by bulk charging and pack balancing. Is there no simple way to set up a lipo pack to be "plug and play" when it comes to charging, or is it always going to be a matter making sure the cells are balanced each time, and having to charge the cells separately if not?
3. Speaking of charging, is it possible to get a "smart charger" where I would be able to plug it in overnight and sleep safely knowing that it will cut off at 4.15v, or is there no such product reliable enough for this?
4. My electronics knowledge is next to nothing and my previous build was assembled from, more or less, turn-key products. Would you guys advise that I stay the hell away from lipo due to my massive ignorance and just bite the bullet on a heavier battery, or should I go for it?
Thanks again for any advice...as always this forum is ridiculously helpful!
-Eugene
-Eugene
