leoms
My bike has a battery pack with sets of 3 LiFePo4 cells in parallel. Each has 3.8Ah and recommends max charge current of 1C=3.8A. All well and good, I try to charge the bike even slower than that. But I'm interested in running my regen brake as hot as possible, because (at least for now) it's my only rear brake and it's not powerful enough as a safety backup if capped at 3x3.8A. And also just because it's nice to have more regen, and I'm interested in finding out whether I can get away with it.
So my question is: What happens if you exceed LiFePo4 charge limits? Are the limits based on thermal dissippation, in which case it would be OK to way exceed them as long as the average over time is not too high and the temperature doesn't climb too much? I'm sure at some point you chemically cause problems, build dendrites, or something, but how worried do I need to be for a brief pulse? Put another way, if my battery's max rated charge current is 3.8A, how do I determine the max safe 10-second charging current? I am fine with modest battery damage, I plan on avoiding using the brake this hard very often.
Thanks!
Thanks!
