liveforphysics
100 TW
I'm using size #35 racing kart chain and steel sprockets... No bicycle chain, except for what your feet use to pedal.
I've ran +50hp in karts with wildly built RM250 engines on this size of chain with no failures. Reduces a lot of weight over using 520 size chain.
Total vehicle weight will be under 70lbs. I'm hopeing to be under 65lbs, but I don't know how much the battery brackets and armor will be. It will definately not be equal or greater than the weight of regular dirt bikes. For example, it is a under a third the weight of my lightest bike, my KTM200exc, and a bit over a quarter the weight of my KTM300MXC, and just 1/6th the weight of my GSXR1000.
I have 1kwh of battery right now, and I can easily make it 2kwh of battery if needed at an additional weight penalty of ~14lbs. (LiPo is very light)
It's just a toy. If it can hold it in a wheelie up to freeway speeds, I will call it a win. If it manages to hurt me in a wreck, I will call it a double win for giving me some excitement.
Also, my work is just 3 miles from my house, so even dumping multi-kW power the whole way, it should work out fine. 2100w charging will make for quick turn-around times when I do drain the pack.
