Ypedal
100 TW
Not exactly fast enough.. but looks the part !
[youtube]FF6t016ueUs[/youtube]
liveforphysics said:Sorry about the long delay, I'm climbing a mountian, and everytime I'm on the back side I get no signal on my phone.
liveforphysics said:They do not use a differential, they use a spool in its place in a standard ring and pinion live axle. Differentials are extremely unsafe for cars with multi-thousand HP.
Since this rear axle has 6 critical suspension link points on it, it is always sold included with the chassis. Available rearend gearing ranges between 2:1 all the way to 6:1, and every possible step inbetween, and its all easily available and cheap.
Cars running in the 4s and low 5s are 1 speeds. Just a clutch that slowly clamps down until about 3/4 track when it finally grabs solid.
liveforphysics said:Basicly, for your 15 grand, you would have a chassis that is all setup. You bolt your motor in, make a custom driveshaft coupler to connect it to the input of the rearend, mount some batteries, a controller, wire it up and you're good to go. I think I could probibly have all the motors mounted and invincible driveline built in maybe 2 lazy weekends. Very easy stuff. I would make my own 5,000amp 500v controller, which would cost about $1,500 in parts, and take another couple weekends to build. Brushed controllers are sooooo simple.
liveforphysics said:If you want me to find you a chassis, crate it up, and send it to you, I could be persuaded to do that for you.
average 30-50C discharge, charge at 3-4C, and have over a thousands cycles
liveforphysics said:My Civic's engine in a the civic chassis can do a 10second run. The same engine setup in a drag chassis could do 8s, and the record for a more built-up version of my engine in a drag chassis has run 7s, and holds the world record for a NA 2L 4cylinder.
If you wana win drag races, a drag chassis is a massive advantage. When my street car runs up against dedicated drag cars, I have to have every thing perfect, and I gotta have about a 50% better power to weight ratio to overcome their awesome ability to put it up on the chip, and let em' hang. Hit the chassis with everything you can throw at it, and it sucks it up and asks for more. That is perfectly suited to taking advantage of the insta-torque hit an electric motor. Streetcar chassis just can't do that. And don't get me started on AWD. Ruins handleing, makes a car boreing, and do nothing to help traction at the drag strip (cause fast stuff with the rear wheels powered will be having no weight on the front tires when they launch, which is why all the fast AWD stuff gets converted to RWD when its gets fast.)
Doctorbass said:Let say you become a winner in EV drag race in your country.... Ex Killacycle, Plasmaboy...
Now you are invited to international event.. wich EV battery do you believe that will be allowed the easyest to cross the border?
400kg of Lipo
or
400kg A123 with that approaved MSDS ?
400kg of Lipo
or
Doctorbass said:Have you any pics of that 11" motor??.. Because - or 2 MegaWatts in a motor is .. IS.... ISSSSS... unimaginable...what kind of brush it would use??.. Nirogen presurized motor to blow out the plasma to prolong their life?...
The guy that make the killacycle motor completly need to rebuild them at every event.. or ... race.. for... "only" 0.5 Megawatt..
Doc
Jeff said:Hah, I nearly pissed myself laughing at the image of those Thunderdie cells installed in a drag car :lol:
All they'll do is sit there and get hot, and maybe even swell a little bit...
I don't intend to sound too pissy, but;
With dual 11" motors, you'll need either a huge LiPo pack wrapped in Nomex with an ejection lever to dump it. Or, something along the lines of twenty five parallel A123 M1 cells, with 80 clusters in series.
And silver plated fine strand copper 00 wire to hook it all together with.
Headway 38120? forget about it.
Either way it's certainly not for the faint of wallet.
Thanks, That was a riot! Jeff
CroDriver said:Jeff said:Hi Jeff
I know That ThunderSkys suck, I'll find some other use for them. This BMW was my first "test" build...
Have you sold your A123s?
Jeff said:![]()
