thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
After toasting my Turnigy 1-6S charger after mistakenly plugging the full battery voltage to it's output leads, I need a new charger.
A friend recommended the icharger 1010b+.
They have in fact quite nice products, but I now worry as those things are totally not fool proof: (we all make mistakes sometimes)
You would expect that such a device which can detect wrong voltages or reverse polarity, would not suicide if it see 50V battery by mistake, or 30V as input when it's supposed to receive a narrow range of 10-18V only.
Another disturbing usage issue with those chargers is the huge inrush spark when you connect your battery, including through the delicate balance leads. This is really scary every time I use it...
Are there any more user-proof products out there which are tolerant to higher voltages without breaking up? We all make mistakes sometimes, and many of us use more than 36V battery packs...
The second question regards choosing between up to 10S charge or 6S one.
The 10S have a single 10S balance port, and then you have an adaptor to get the lower series numbers, like this one:
http://www.icharger.co.nz/2-10s-jst-xh-balance-board
The problem with it, is that I find it problematic to balance-charge a 7S battery which has 4S + 3S balance leads.
With the Turnigy 1-6S charger - I did balance charge for the 4S part first, then the 3S. With a 10S charger, I think it would be impossible to charge the entire 7S battery at the same time and in fact I think I won't be able to balance-charge it at all without hooking up additional wires, which again, brings the user-fault issue.
I find that eventually, the easiest and safest way - is to use the above chargers only for 1 cell charging at a time. It takes longer, but I anyway do it once in a while when I check that the battery is fine. It's actually not so slow compared with the balance-charging mode of the above chargers - they can only drain 300mA or so during balance charge which is NOTHING for a 20Ah cell. I am much faster with charging all the cells in series, while monitoring and plugging an external load resistor on the higher than average cells.....
I will be happy to hear your experience with those.
