I originally started this in the ebike forum, buried in another thread, however, it has to do more with batteries and as such really belongs here (plus it got lost rather quickly in the other forum)
I have a 36 volt battery pack for my bike right now that I'm really happy with, however, once a week for around 2 miles I need a higher top speed than I can currently achieve (even with pedal assist).
To do this I plan on adding 12 additional volts to my system by wiring the old and new pack in series for a total of 48 volts nominal.
I've been getting lucky opening "dead" laptop packs over the past week when I snagged a few from a friend and to date I have 14 cells which have been tested/ charged with another 12 or so charging now (well 2 at a time but I have 12 that need to be charged)
However, I need a way to connect these cells together in 3s 4p or 4s4p pack to add the volts I want (probably end up with 3s4p because 4s4p hot off charger with other pack is about 61 volts which is too close to the cap ratings).
I was thinking of using 4 lengths of pvc cut to the correct length (3 cells) with a spring in each endcap and having all the endcaps wired together to produce the volts I need at 9aH. The cells I'm using are high quality Sony ones rated at 2C continuous and 5C for 30 seconds, plus my controller is only 22 amps so I should be fine there.
The only thing is that I don't have the time to put this together right now... which is where hopefully one of you comes in
I'm willing to pay for parts, labor, shipping (within reason obviously) for someone to assemble a 3s4P holder for me. The PVC idea was only a thought although it would be easy to grab the materials and cheap. I need to focus on my undergrad work here, however, if anyone has some free time / wouldn't mind making a little extra money please let me know if the idea is even feasible
