ccmdr
Hi guys, before I start doing anything drastic and damaging my hub, does anyone have any experience with removing loctited and loose fitting/rounded T20 'Torx/Star Security' bolts, as google has failed me? This is by no means my first rounded bolt/screw, however I've yet to have issues with the Security type bolt, and the remaining 7 of 9 are stuck fast.
Had the common phase wire cut on HS3540 and trying to change the cables. I've purchased 'special' T20 titainium coated bits after my other ones shattered. Two bolts have come out with heavy lubrication and heating the hub. I've noticed however there is a clear type of loctite holding these bolts in. The bolt heads are sunken into the hub inhibiting any bolt extractor/socket/molegrip type attack.
Tried so far;
Lubrication soak - Heat - Hammer whilst turning - hub mounted nice and firmly on the horizontal axis with no means of escape = Two bolts removed
Modified my impact driver to fit Torx Security bits = Torx Bit twisted and warped... kind of expected that, shear ratings etc
On the worst fitting bolt 'encouraging' a T25 bit into place = need too much 'encouragment' to get a firm grip in the star
After the T25 tried the flatblade on its vertical/hammer rotation dance = just rounded one of the star points
Next action:
I can dremal a groove for a flat blade = hub damage
Attempt to drill out the Security Torx, although the pin in the middle of the star will create an offset hole = damage thread then retap...
Weld bolts onto the 7 stick bolts and try to remove = likely damage hub or worst case weld the stuck bolt to the hub
I'd like to shift the 'security pin' so a standard extraction is possible, but fear removing the pin via bend fatigue will just leave a smaller node to work around.
Any other ideas' from the mechanically minded?
Tried so far;
Next action:
