looking to cut a 9t or 10t sprocket, has anyone seen any software or somethign online that will let me print such a thing 1:1 on paper to use as a template, I've seen things for cnc in dx code and stuff but i'm building by hand with hand tools....
try this software:
http://www.idleamusements.com/sprocketeer.htm
its called sprocketeer(thanks for the link amberwolf! )
its free to download and ive used it before to make my 7t sprocket.
try this software:
hmm. i have sprocketeer v1 and i use it with cadSTD lite version and it works for me. i also have autocad and it works on there as long as i open it as a dwf file because i saved it as one. im not so sure about using the g-code for it.
LI-ghtcycle said:
I'm curious, do you notice any significant wear with a smaller sprocket like that? I would think you would with such a small cog!
not really, but then again, i dont use my bike as often as i should. i only have about 500 miles on my bike since ive built it last year which im sure is nowhere near some of these guys have on their bikes.
flez1966 said:
7T, I thought I was going a bit low at 9T, hows it been? did you have to use a guide wheel to get more angle on the chain etc
im actually using a 6t #40 chain at the moment and its still working, so far. i do run a chain guide wheel to keep everything in line for the front and rear sprocket. since the 6t is the motor gear, i tried to give it the most wrap as possible, close to 180 degrees. but one thing about it is that it is quite noisy, which i dont really mind.
use sprocketeer to display on screen the little picture of my sprocket, take a screen grab with the prtscn key, load the image into mspaint or similar, then print it out at like 80%/90%/100%/110% and see which is nearly right, then fine tune in 1% increments till its right, glue to steel and then start to cut and file...
on a good note my 14t freewheel arrived this morning which is goint to be for the bike motor, the sprockets i'm working with here are for the trailer motors
edit: Found a lovely drawing guide...
http://www.gizmology.net/sprockets.htm
guess its time for a sharp pencil and some old school paper...
If you are talking bicycle chain, a #40 sprocket has the same pitch and barrel diameter. You can down load dxfs of sprockets from McMaster-Car and with a little scaling in a cad app you will have a full sized drawing. A #40 sprocket can be cut roughly in half and used with bicycle chain.
I was working out the front on the drive, it started to rain, i gave up for the day and just left the assorted bits covered to protect them a bit, I brought the power tools in but left the hand tools/screwdrivers etc out all night, they were still there, but the wheel i had off loose for measuring the motor/chain length had gone.
other pics of sprocket being built here http://flez1966-beerbuggy.blogspot.com/2011/02/little-sprockets.html
