mrzed
Hi all,
I am running a 9C kit from eBikes.ca with a 36v/8aH NiCad. The site states a recommended 1v per cell as the low voltage cutoff to prevent cell damage, that would be 30v.
With the cycle analyst showing around 6aH discharge, the pack runs around 32-33v with no load. Running level, sags down a little over 30, but for acceleration and especially up steeper hills, it can readily sag below 28 for short periods.
Should I:
1. Set the LVC on the cycle analyst? I would expect this would cut off power when I often want it and so I have not yet gone this route
2. Carefully feather the throttle on hills to try keeping it as close to 30 as possible (what I am doing now)
3. Not worry about sag and just not let the pack discharge below 30v at rest
Should I:
