low
M
mark 324
Guest
Hi there I dunno where to write but I have problem whit bms on my battery It's not the charger... It is the LT error...
The charger stops because bms shuts down because LOW TEMPERATURE.... Minus degrees.
Every charger will shut off..?any can help fix it won’t let charg my battery it’s stops charging after I plug charger thanks
Did you forget to plug in the temp sensors on the BMS?
I think it shows a negative value if you don't use it, in this case the BMS thinks it's freezing cold and will prohibit the Battery from being charged.
There are two solutions that I know of.
1. use the temp. sensor
2. reprogram it on the PC app to not use any temp sensors.
stop spamming your question.
stop spamming your question everywere.
Merlin said:
calm down dude...its only one topic and hes may not that experienced using forums.
whats your idea to help with his bms?
it was 4 topics he was hijacking and 2 doubles he was also creating so he was asked to stop spamming. not knowing how a forum works does not apply if you are spamming the same copypaste everywere. most of them are deleted my mods already.
and my take is that either the bms posesses a form of AI unseen to man and started to use unused temperature sensor ports all y itself, the user enabled ports that are not in use, 3 temperature sensors all failed at the same time or wires are disconnected.
Log temp issue at their support portal @ https://github.com/smagicld/xiaoxiangBMS/issues
mark 324 said:
Programming cable of controller kelly 7212s where I can buy ?
https://kellycontroller.com/shop/sm-4a-to-rs232/
https://kellycontroller.com/shop/bluetooth-adapter/
mark 324 said:
Can I disable on app android bms temperature sensor?or I need programming bms cable?
Yes, you need the UART box:
https://www.aliexpress.com/item/33043068582.html?spm=a2g0o.productlist.0.0.1b80396docjUFo&algo_pvid=957cd3e0-817c-496a-8074-c2a406404174&algo_expid=957cd3e0-817c-496a-8074-c2a406404174-5&btsid=72912c9e-ebf2-42f8-8518-08c502c09fce&ws_ab_test=searchweb0_0,searchweb201602_9,searchweb201603_53
Click on UART box and then choose your preferred shipping option.
mark 324 said:
When I do angle configuration 170 it cutoff power battery is to weak I think ?
yes, and you need to lower motor current in the last tab.
Maybe it's a wrong throttle type setting, try switching it to the other value indicated in the comment box.
The Domino throttle is a Potentiometer throttle, change the throttle type in the Kelly app.
mark 324 said:
Hi I installed to ca analyst throttle domino in screen show is working but wheel not spinning any know why?thx
this is like asking " my car is not starting, why is it not starting?"
why are you looking at a CA when you have other issues to work out first?
To get good answers you need to not only ask the right questions, but give lots of relevant details so others can start asking you questiins to clarify, test things.
If I just ask you, he having trouble sleeping these days, can you tell me why?
Any suggestions or answer you give is just guesswork
It means is sees too high a Throttle voltage, you could have reversed the wires or maybe you need to tune the dead zone settings.
