CUDAcores89
1 W
- Joined
- Aug 28, 2016
- Messages
- 51
About 6 months ago I built an ebike and it has been working great. I use the thing every single day to get to and from work. So far I have put about 2000 miles on an ebike battery I built from "dead" laptop batteries and I have started to notice that the cells sag in voltage much more than a small lipo pack I also keep around for emergencies. I know why this is. It's because when one uses old, used cells that were simply never designed for such a high discharge rate they tend to sag quite a bit under load.
Now here is where the question comes in. I am looking at either purchasing/building (probably building to decrease the battery cost and avoid the battery murdering systems) a new battery pack. But this one I want to last as humanly possible. For the sake of argument, let's ignore the resulting weight, capacity, and size (both dimensional and capacity) of the battery and just focus on the chemistry. What battery chemistry is going to last the longest? There are several I could use, so I am going to compare them below:
Lead acid - The only advantage lead acid has is low initial cost, that it. Because it only lasts a few hundred cycles it must be replaced often meaning the cost per cycle is quite high, so that's out.
Nicd - Nicd does have some advantages over other chemistries. It can be charged and discharged quickly and last long if the battery is maintained, these cells have been proven to last thousands of cycles. The problem is not many companies make nicd batteries anymore so the initial cost is quite high just because these cells are harder to find.
Nimh - nickel metal hydride batteries are similar to nicd, but they have a higher energy density and do not have a memory effect. I could use these cells and they are an option. But I would have to find high-drain ni-mh batteries and would likely increase the cost per cycle as the initial cost would be high.
Lipo - I straight up can't use lipo. These cells are very powerful and many can (i'm speaking of HK lipos by the way) easily put out a 20C discharge rate. The problem is these things only last a few hundred cycles at best meaning the cost per cycle is quite high, so these are out.
18650 li-ion - This is the form factor I use currently. These cells have better cycle life than lipo, are safer then lipo (at least in my experience) but still only last 300-500 cycles. This is the reason why I am looking for alternatives.
Lifepo4 - This is the most promising one. Lifepo4 has a higher energy density than the nickel-type batteries, and many are rated for up to 2000 cycles. Their energy density is however worse then lithium-ion, but they make up for that due to the fact that they last much longer. They are also the safest of all lithium-type battery chemistries.
So yesterday, I was browsing ebay, and I found this:
http://www.ebay.com/itm/NEW-Box-of-80-Tenergy-LiFePO4-32650-3-2V-5500mAh-Rechargeable-Batteries-5-5Ah-/351864363778?hash=item51ecc01b02:g:YPoAAOSwoi1X87JG
I can get an entire case of 80 lifepo4 cells for $150, so this seems like a really good deal. And after checking the datasheet:
http://www.all-battery.com/datasheet/30069-0_datasheet.pdf
one cell has a maximum continuous discharge of 10 amps. This is good news. I could buy an entire case of these cells, only use 48 of them to give me a 12S4P 38.4v 22AH lifepo4 battery pack. Then sell off the rest to get some of my money back. This is currently what I am looking at doing.
To help answer my question here are my bikes specs:
36v "250w" (it actually draws 500w under load) rear when ebike hub motor I bought from ebay.
36v 10AH ebike pack built from dead laptop batteries
The motor draws around 12.5 Amps under load
So which should I do?
1. Buy those tenergy lifepo4 cells in the ebay listing, and build a pack from that.
2. I could also look at building a nicd or nimh style battery pack.
3. This wasn't mentioned but I will mention it here. I could buy 150 2500mah 18650 cells and simply only charge and discharge the pack 50% of the way. This would extend the life of the pack to 2000 cycles with about the same energy density of lifepo4.
Or is there something else I could do that I haven't looked at.
Any suggestions?
Any suggestions?
