Luckeep e bike motor cable replacement
lbert327
Coral Springs, FL. 33067
Hello everyone, Happy 4th of July!
I have a young neighbor that lives across the street from my wife and I in Coral Springs, FL.
His parents recently bought him a Luckeep electric bike so he can get himself back and forth to his new job at Publix.
Unfortunately, he got a rear flat tire and tried to remove and replace it himself. In doing so, he damaged the cable right where it leaves the motor hub and is not repairable. Therefore, it must be replaced. I've been an electrician for over 45 years, understand it well and also watched a couple of you tube videos on replacing this cable. Unfortunately, this cable isn't available on the Luckeep website. I looked on Amazon and they have some that are close but, not the correct cable. Luckeep's website only has a number that only receives sms messages and email addresses that no one answers. I've tried both methods a few times and have given up on Luckeep bikes.
Does anyone know where ai can purchase the cable alone without having this hard working kid having to buy a whole new motor? Anyone's help 2ith this would be greatly appreciated since I'm just trying to use my skills to do a good deed for him.
Thank you to anyone in advance for any help you might have in finding a Luckeep bike motor hub cable.
Regards,
Larry
...he damaged the cable right where it leaves the motor hub and is not repairable.
It most likely is repairable, especially by an experienced electrician such as yourself. Should be able to open up the motor, unsolder the wires, remove, fish new wires thru the axle, solder them, and then splice the outer ends to the connector. Keeping track of which wires go to which connector pin.
