@ 1min 25 seconds you remove the XT60 plug by .... Pulling on the Wires
Often XT60 as well as XT90 plugs are very hard to separate so it is best when the plug is in such a location , to take a pair of pliers to grip the plug itself instead of the wires .
@ 6 min 40 seconds you go for a straight run , before you start off the voltage is reading 51.49 apx .
when you finally settle out at a constant speed @ 7 min 15 seconds it is showing 47. 49 apx volts
That is a 4 volt voltage drop , and at that time you are only pulling 17-19 amps .
and for a few seconds the voltage got even further down .
Even though your battery was not fully charged a 4 volt sag seems high to me.
Some Battery experts here on E.S. need to weigh in on this .
What make and model of batteries are in that bike ?
You say the pack is 13 s , how many cells are in parallel ?
robocam said:
I put a power meter on my X-1 to confirm whether or not I have a Ludicrous controller. Next time I'll have to fully charge the battery to see what it can do but the results are pretty good. https://youtu.be/_YB7oNEtbNI
