Reported to have charging problems, this pack hasn't yet been opened up, but first I thought I'd just test the charging. It doesn't have any brand or manufacturer or vendor markings on it, but it is supposed to be one of these Luna Cycles packs:
http://web.archive.org/web/20150822034024/http://lunacycle.com/batteries/48v-samsung-18650-battery-pack-10ah/
Took pics first, including this label that might be a double typo, but somehow seems more likely to have been meant to deceive shippers into allowing this on shipments it wouldn't otherwise qualify for due to it's capacity:
The label (mis)reads:
"18650 LI-ION BATTERY"
"4.8V 10AH"
"48 WHR 26F"
when in fact it is a 48V 10Ah 480Whr pack. :/
(either that or it is dangerously overcharged and could explode at any moment. :lol: )
It arrived here at 49.3V with no load, tested with multimeter on both charge and discharge ports, just measured with voltmeter on existing wires/connectors. Assuming it's balanced (which I can't check till it's opened up) that would be a hair less than 3.8v/cell.
Had no connector on discharge port, so I then added the Anderson SB50 I use on everything here, so I can plug it into the trike (or bike) and do test rides with it for monitoring/etc.
The automotive plug on the charge port I replaced with Anderson PP45 that I use for charging (it's what is on the Satiator which I'll be using to test charge with).
Assuming that 4.2V/cell is max charge voltage, I set the Satiator up for 4.2v x 13s = 54.6v full charge voltage, based on one of the preloaded "48v lithium" charge profiles, for a 4A charge rate, which would be 0.4C.
It charged for a while as I made dinner, but I managed to mostly-unplug the Satiator from the wall as I was moving an appliance cord from that outlet panel to a different one, as the voltage got to around 53v, and didn't notice until the Satiator had powered off and cleared the screen, so I have no idea how many Ah it put into it at that point.
I restarted the charger, and got about 1.4Ah into it before the Satiator reported a "power fault", and had to be restarted, but it only took anohter 30 seconds or so to get another fault, somewhere around 56V I think it said before the fault.
I'm presuming based on the voltage that the BMS was cutting off charge, and somehow that caused a problem the Satiator couldn't deal with on it's own, but I don't know yet.
I then hooked up the pack to the SB Cruiser, and rode around the backyard a bit, low and bursts of high throttle, one and both motors, etc., to put a little laod on there and drain it some, to retry cahrging again.
After this I retried charging, and no more power faults but it still stopped somwhere around 56V (couldn't see exactly) within a few seconds of plugging in and start of charge with "charge complete", and then the voltage on the Satiator flickered so fast between 50-something and 60-something volts that I couldn't read what it said.
I changed the profile to reduce current to 1A (0.1C) with no change in behavior.
For now I am just leaving a Turnigy Wattmeter on the charge port, where it says it's 53.17V (as a Watts Up similarly says about the discharge port), until I finish typing this up. Then I'll take them off and go store the pack in one of CrazyBike2's metal cargo pods outside overnight (in case anything dramatic happens to it, as unlikely as that is).
Presumably if it is a cell-balance issue the BMS will do some balancing overnight, then I can retry charging tomorrow.
But first I'm going to test it on a "real" ride with the SB Cruiser on my work commute, to see how it performs, and to drain it some. (should take around 4Ah or less).
Assuming this *is* a Luna Cycles pack, then the specs from the archived page above are:
"4.8V 10AH"
"48 WHR 26F"
