Re Lyen Controller I would really appreciate some advice and lessons!
My system
48 V BMC V3 rear used
new
Cali bike 15 ah battery
CA 3
three speed switch
lyen controller.
I to am an ebike newbie but have a builder and mechanic, both car and bike, background.
With my fluke and very limited knowledge on the electrical side of how these work my diagnose
With only controller powered, no CA plugged in
1.54 V going to controller
2. On controller side phase wires show 11.88 V
As I twist throttle no change.
What should the voltage be at this point, I assumed 0? And that the voltage would climb as the throttle twists?
3. As I retested phase wires I would get a minimum voltage on 1 ( below 1V) and still 11.88 on two others.
4.Checking hall wires red to ground 4.45
blue and green go 5.0 V to 0v , yellow goes 4.82 V to 0, as you slowly rotate wheel backwards.
Checking Throttle connector at controller it has 3.4 V coming off controller green black increasing to 3.63V as you rotate ?
When I checked this throttle through my CA it has .6V ranging up to over 4 V as twisting.
5. Checking resistance on phase wires at controller ground to all phase wires shows just under 10 K ohms
6. Checking resistance on all phase wires from controller power on controller shows between 14 and 15 K ohms.
Really appreciate any tips or links explaining whats going on.
This on a Yuba Mundo cargo build that runs 95% on no hills carrying two small kids and groceries while I pedal as well.
Appreciate your time
Donny
My system
new
CA 3
three speed switch
lyen controller.
Donny
