simplystupid
- Joined
- Jul 20, 2015
- Messages
- 14
So how does this configuration achieve the translation from low number of turns into low rpm?
I wonder if someone really knowledgeable on the physics of motors can explain why this configuration works in the 3000rpm range.
Having dismantled motors from the age of 6 and built and rewound many since then,
my specific question is about this;
There is only one effective 'turn' between the relevant brushes supplying current.
There is also a lot of surplus copper, carrying current but not in the magnetic flux. In order to take the top/bottom paths of the rotor geometry.
More than actually in the flux. This would normally mitigate against high efficiency.
So in spite of a 1.5 Tesla or greater field, the back emf at 3000rpm is not going to be very high. Neither, it seems conventionally, would the torque.
One turn on a typical PM BLDC outrunner 'wye' or 2 pole BrushedDC, would need to operate at perhaps 200K or even more rpm!
Eight magnets and brushes is not the answer, the connected windings at any one rotor angle are all running in parallel. PM car starter motors now sometimes have 6 poles.
