kZs0lt
I want to bring out maximum performance from my 12 FET controller.
What would be the max. safe Phase/battery current?
It is a EB212 controller with stock shunt(2 wires, aprox 2.5mOhm), fitted with (12) 4110 FETs.
Battery and Phase traces have been beefed up considerably, battery wires are aprox 4mm2(AWG 11), and Phase are 6mm2(AWG 10).
Generally it is said that 4110 mosfets can take 100a continuously. On the spec it says 120A limited by package. Others say the FET legs are limited to 75a.
Would I be safe with 100a battery and 200a phase? Or should I lower Phase to 2x75A = 150A? Can I crank up battery current even more, or it should not make a lot of difference anyway?
Oh, my battery is a 18s2p a123 M1 cells, so about 58v nominal with 4+Ah. So it will be pretty hard on them, but they can take 30C continuously, or 2x70 = 140amps. I think I'll go for 100a battery for a somewhat conservative max.
And the motor is a 9C 9x7 winding in a 26" wheel. I know this power level can damage it, but the Phase wires are upgraded to what I believe are 12AWG cables, and I would use this power levels only for short periods, for accelerating like 10's of seconds.
I'd like to set up this bike for good accelerations, and wish to have it working reliably at least for some weeks.
What setting would you recommend?
What other needs tuning? Do I really need to lower the shunt value?
P.S.
At the moment I am not sure what are my limits, because I have programmed it as a 209 board with 57a battery / 120a phase because 57a was max in the Parameter designer. CA sees about 70-80a max continually, and 100a max momentary on CA. At these settings however the controller cuts out from a dead stop with full throttle. Maybe lowering the shunt could help?
P.S.
