alexis57 said:
As I said, if I increase the input voltage, I will decrease the input current. (I consider same losses with 13s and 14s)
Yes I did see that but just wanted to make sure. Some people do not understand that basic relationship
alexis57 said:
NeilP said:
So your problem is Voltage Sag after you have been riding for a while ???
increasing the voltage at the start of the ride is NOT the answer
I have a new battery pack 13s4p means 11.6 Ah Panasonic NCR18650PF rank B. No problem with it.
Explain why increase the voltage is not a solution ?
Well if you increase the voltage it is sort of a solution, but you still have the voltage sag , and you then risk damage to the gear train.
With even a new small Ah battery pack like you have made with B grade low C rating and quite 'saggy cells'
https://endless-sphere.com/forums/viewtopic.php?f=31&t=61608&start=25#p959214
You are always going to get this at the end of charge.
Giving greater capacity will lessen the effect. as will a pack made from better cells
alexis57 said:
I'm surprised, no one told me about the most important thing in an electronic circuit which is the capacitor's voltage...
I reply to myself, I found the capacitor's voltage is 62V then we cannot increase more than this voltage.
I'd say, no problem for the display or anything else since dcdc converter(s) exists.
No one told me lots of things..I read it all or found by reading the forum my self. If everyone told you everything there is to know about e-bike batteries in one hit, you would not take it all in any way. I mentioned it and you found out more, that is good.
alexis57 said:
My problem is not a capacity problem since if I stop for a small rest, it's ok.
To me stopping for a small rest and giving the cells a chance to recover and cool down is a perfect indication of a capacity , "C" rating and cell quality issue.
What is the max amp draw from the battery pack?
If the spec I read
here: correctly, then your pack max rating continuous is 40 amps. So from my own personal experience with packs over the past 4 -5 years, for good cell life and reduced heating i'd not be wanting to draw more than 10 continuous with occasional peaks to 20 or 30 max. And even then you are runnign at quarter of max rated. Too high in my experience for a reliable pack
For instance my pack on my bike is 20s4p nano Tech lipo. So that is nominal 72 volt 20Ah pack. I charge to 83v. According to the Hobby King Spec they specify 25 C continuous, 50 C burst, which gives 500 continuous 1000 amp burst.
I run at peaks of about 140 amps. If I wanted to go higher I'd think seriously about adding more parallel to keep the cells very much under rated.
At a guess ..what are you running current wise? 10-15 amps? hopefully not a lot more. That is 50% C rating capacity ..the cells are going to get warm..and performance will decrease as IR rises.
alexis57 said:
Id say it's more the voltage sag after 1h. With an input voltage higher, this will be solved.
but you will still be getting the voltage sag, just starting at a higher voltage. Still putting the cells under the same load.
I have a pack here, also 48/50 volt...12 series Lipo Zippy 5000 5ah packs 'Only 20C rated" I'd not use them on a high power bike
it is 12s2p, 10 Ah capacity ..so 200 amp 'advertised continuous' . Max I have controller set to is 25 amps, so that is one eigth of advertised rating.
I'd not want to draw much more out of it and keep it reliable.
Small low grade cells , small pack , you will get voltage sag. and the only real way out , if it were me is greater capacity or better cells.
