I'm trying to measure the consumption of the battery charging for the Evolve carbon series, the Evolve battery equipped 10 amp 36v lithium polymer, the load is done with the rapid charger 42v 4amp
has not been able to verify consumption because in the first measurement has marked a Overload
Could anyone tell me how to program the Overload parameters?
I use a GreenBlue GB202G - Wattmeter meter energy consumption with these features:
GreenBlue GB202G - meter energy consumption
Nominal voltage: 230VAC 50Hz.
Max Power: 3600W, 16A.
Working temperature: 0 ° C - + 50 ° C.
Measurement scales: 200V ~ 276V (± 1%), 0.01A ~ 16A (± 1%), 0,0W ~ 9999W (± 1%), 45Hz ~ 65Hz (± 1%).
4.OVERLOAD setting for GreenBlue:
Press“ENERGY/+” button to select the “OVERLOAD” screen,Press“SET/OK” button more than three seconds, it will enter into “OVERLOAD” watts setting,now“W”is flashing.press “ENERGY/+”or“COST/-”to setting“W”or“A”.
Remark:
A、If you press the button but don't do any response, it will quit the OVERLOAD automatically. B、When current load power exceed the overload parameter which seted before, the “OVERLOAD” will keep twinkling, it means dangerous and have safety loophole, system regard as initial parameter 3680W.
Rapid charger
Case:Aluminum
Certification:CE
Color:silver,black
Dimensions:153*90*50mm
Input voltage:180~264V
Max power:180W
Output current:3A
Output voltage:48V
Rated Voltage:58.4V
Type:Electric
Use:E-bike,E-scooter
Weight:0.9kg
Specifications:
Electric Bike Charger:Automatic 3-stage charging, switching mode & high frequency.
Description:
Electric Bike Charger Specifications:Size:153*90*50mmNet Weight: 0.9KGWattage:180WFeatures:1. CC, CV 3-stage charger2. Reliable, elegant3. Small size, light, aluminium housing4. Efficient (efficiency ≥88% full load)5. There is a fan to create forced air to cool the charger when temperature goes as high as 45.6. Pursuing the best quality, Kingpan always try his best to offer the most reasonable prices. And the more you order, the more discount we could offerOperate Condition:1.Temperature: -10~45 Degree2.Hi-pot: ≥AC1500 (P to S), ≥AC1500 (P to FG)3.Life Expectancy: 50, 000H at 25 Degree4.CE certification Apply to:1. USP Battery2. Electrical Scooter Battery3. Motorcycle Battery4. Auto Motive Battery KP-S for Lead-acid, Silicon BatteryKP-SL for Li-ion/LiFePO4 BatteryLead-Acid: 12V8A, 24V5A, 36V4A, 48V3ALi ion:4-cell/8A 8-cell/5A 12-cell/4A 16-cell/3A
Electric Bike Battery Charger
More info:
http://www.plgenergy.com/content/?1093.html
thank you very much
Remark:
Rapid charger
Case:Aluminum
Certification:CE
Color:silver,black
Max power:180W
Output current:3A
Output voltage:48V
Rated Voltage:58.4V
Type:Electric
Weight:0.9kg
Specifications:
Description:
More info:
thank you very much
