I have a Ezee 400W motor with a Infineon 25A controller on a full-suspension bike. It has worked only intermittently lately, and now it doesn't work at all. When given throttle, the wheel only moves a little and then stops.
I have tried to measure the hall sensors with the controller connected, but cannot measure any voltage between black and red. My guess is either the controller is fried or the wires are shorted.
If I disconnect the motor from the controller, can I measure the halls then ? I know I need some kind of power supply, would it work to connect a +5V power source (like 4 NiMhs in serial) between red and black and then measure the halls between yellow/green/blue and black ? What should the reading be then, from 0V to +5V while turning the motor backwards ?
