Hello,
I installed for the first new brake pads on my tektro caliper, I noticed that there isn't enough space to insert an hex key to the inner pad hex screw because it's too close to the hub motor, do you know where I can get the blue key from the video? https://www.youtube.com/watch?v=9OFJE2jIDAU&feature=youtu.be&t=159
access to a 3D printer is not an issue if you know of an available model.. I don't even know the name of this thin key so I couldn't find anything
When adjusting the caliper with a spacer, the inner pad touches the disc, unless I barely hold the brake handle while tightening the bolts, but then the braking isn't smooth at all
Thanks in advance
Thanks in advance
