Hi, I run a mid motor kit from gng electric, just the small 36v/250w motor. However, I upgraded to a 48v/500w battery & controller setup... I melted the windings in the motor. When opening the motor you could see that the insulation material between the wire windings and the armature had failed, sending shrapnel into the circulating motor, and destroying the coils that then shorted. So, I was thinking I should try rewinding this motor with higher quality wire & insulators, and also add som alu-fin cooling on the outside and see how it goes. Eventually I might just get a bigger motor, but I'd like to try as I love the stealthyness of this current setup (small motor underneath the BB).
Does anyone know of a good resource on how to size this stuff? I dont know how many windings (maybe I can count the old ones), nor do I know the proper wire gauge going from 36v->48v... any tips? Also, locally (Sweden) I can buy "laquered" or "enamel" winding wire, which has the highest quality and can take more heat?
Thanks! Sebastian
Thanks! Sebastian
