addicted2climbing
- Joined
- Aug 25, 2011
- Messages
- 212
Hello All,
I am considering building up a mid drive Bafang setup on a Cannondale Contro 3. I have not bought the bike yet, but its likely the one I will buy due to them being on clearance and I also like the unique design. Anyhow, my questions are in relation to the Bafang setup and what I need. I am thinking for a daily commute bike that the 750 watt setup will be fine, but am open to buying the 1000W version if its that much better. Just thinking for a commuter chances are I wont use all the power anyhow. Most of the commute is flat, but I do ride for fun and there are a few good hills in my Area. Commute will be about 12 miles one way from Burbank CA to Downtown Los Angles via the LA river bike path. I can charge at work, but min 20 to 25 mile range with pedaling would be best. I weigh 225lbs.
I am unsure what battery I will need. I have been to the Luna Cycle site and they have many options but unsure whats best for my needs. I would like to optimize the pack for my needs so not really wanting to buy the largest capacity pack there is. Would prefer to keep the bike weight down a bit if possible. The Contro 3 has an integrated rear rack so I am not oppose dot a rear rack battery, but figured that mounting in the frame was preferable. Do I want 48V or 52V? Can I use my RC airplane lipo/lifepo/lion charger? I think its max is 10S however, need to check
Is Luna cycle the best place to buy everything. One concern is I live in CA and would like to avoid tax if possible, yet Gardena is not far away from me and maybe its worth buying local for some help if needed. Other online vendors worth considering? Aliexpress?
The Contro 3 has hydraulic disk brakes and the Disk brake sensors seem janky. Curios if there is another option. Figure its just a hall sensor so my guess something better could be made.
Upgrades? Shift sensor and color display worth the upgrade? What about the special wrench?
Pretty much open to any help or suggestions.
Marc
Marc
