neptronix said:
Honestly i would be happy with something as simple as a hub motor holder that holds a perhaps mid sized geared motor. The idea would be to do that for reliability. Motor burned out? swap a new one in! in fact i'd like to carry a spare motor in the field!
Both my cannondale and my maxaraya have 'mid drives' in the chain line. A 3-6.5lb geared hub motor could be hooked up to either side of the hub. I'd like to take advantage of the freewheel inside the motor so i have very few moving parts.
I would be happy to ship my frame back and forth and pay for you to build me such a thing if you're interested.
Erm... a recumbent frame to Russian Federation? That does not sound cost-effective
(though possible, last I've had a bike frame shipped from Ebay it cost me about 150$ or so... that was a few years ago tho)
Since I do not weld at all and mostly deal with clamped/laser cut/3d printed fixtures that work quite well (though a bit heavier than can be to due to bolts, but than easily moveable/removeable, great for belt tensioning - I'm learning composites for lighter, permanent fixtures) and can be installed by anyone - I'm not sure that is needed.
Having access to your frame would be great and make things quite simple when it comes to tailoring 3d printed bits, of course, but than by using 6384 motor it would be possible to fix it to the *seat* (horizontal) tube (that comes with guide rail, very handy) and tuck it close to your seat because it is very small and should not interfere with your ingress and pedalling, unless I'm mistaken in my measurements. It is a simple round tube, right? OTOH, main tube seems pretty complex in geometry.
Using a single-stage (for the motor, that is) reduction will make the system very efficient, considerably moreso than typical hub motors - high speed motor with thin laminations is great in that regard, that's why I've chosen them (also, cheap
Both of my cheaper motors (1.5 pounds) are happily capable of 1+kw at 26v (about 50a tops), and can be overdriven to nearly 2kw at peak, but care must be taken lest you burn them (though that can be managed by the choice of controller) and it would only be possible when the middrive is spinning much faster than you can spin yourself even given additional reduction from middrive to the cranks.
Those are just a no-brainer for a bent where you do not have as much problems with clearances...
