MiniSpotA spot welder
Going back to the discussion of sandwich spot welding, I have tested this method to weld copper with the MiniA
[youtube]VTtL6Q_ON7U[/youtube]
The scraps at the left are the aftermath of the sandwich method. At the right is a direct spt weld on copper.
Direct is far superior with this machine. No need for the sandwich. 4-5ms on 3s is enough for 0.05 copper.
[moderator edits to remove embedded spam links]
It's amazing, and even more so that he left the plans up / AFAIK it's open sources hardware ! I had lots of fun trying to make mine. I just need foil and a bigger battery to test it with [emoji14]
I decided to make myself a challenge and shrink it down to 1cmx10cm with smd so I can machine a pen shaped heatsink... If I did it'll right I'll try to keep shrinking it (for science of course).
Sent from my CLT-L04 using Tapatalk
what connector comes with the spot welder
rojitor mentioned he used this https://hobbyking.com/en_us/turnigy-battery-nano-tech-5000mah-3s-65-130c-lipo-pack-xt-90.html?___store=en_us
but not sure if it was for the boss or mini
i was thinking about this one if it's xt60
https://hobbyking.com/en_us/turnigy-nano-tech-3300mah-6s-45-90c-lipo-pack-xt-60.html
