Hello all. New to the forum and e-bikes generally. Seeking some advice on a conversion project.
This trike was previously used to shotgun parts around a cement plant, so the frame is quite heavy duty - roughly 140 lbs. I am planning a conversion project to turn it into a mobile DJ booth, which would potentially carry turntables, DJ CD players, a mixer and smaller monitors. If it's feasible, I'd like to add an e-bike motor with enough torque and power to propel the combined weight with rider. Further I'd like power the bike motor and the DJ setup with a compact fuel cell that can be recharged via pedalling, AC power and solar panels. I may also look at widening the wheelbase in back to accommodate a larger box.
It's an ambitious project that will likely take years to complete. My first step is determining whether a motor exists that can meet this core push need. I'd appreciate feedback and recommendations on motors than can handle heavier loads.
Here are some initial weight specs:
DJ Tricycle specs:
Base weight: 140 lbs.
Technics 1200 turntable: 17 lbs. x 2 = 34 lbs.
Pioneer CDJ 2000: 10.14 lbs. X 2 = 20.28 lbs.
Xone 32 DJ mixer = 9 lbs.
Rider weight: 180 lbs. (average)
DJ Tricycle specs:
