John Bozi
delete
I'm not sure if you're joking or you some how actually find this insulting. I thought only neanderthal like characters in movies took offense at what has to be one of the most genuinely uninsulting, generic, throw away jokes there are. Especially considering I just put "your mum" without any context or the usual implied negative qualities or descriptive attributes that follow. It was clearly just thrown in as a joke and I would have put it there just the same regardless of who posted the question. Anyway, as you wereJohn Bozi said:go make jokes about something that is uninsulting
John Bozi said:pendragon8000 said:I'm thinking 21s .
Why?
Your the second person who has said this odd number is there ideal who has not tried it. It interests me because came to it by the limitations of grinfineon controller, not my logical choice usually controlled by hk lipo choices of 6s and then logical even numbered charging ports.
24s2p makes sense and 12s4p makes a lot more sense for realistic riding speeds, battery health etc. but too slow.
Now I saw they've got 8s lipo on hk with a single balance plug....
16s2p is looking very sexy and even, although it won't fit my triangle but have been contemplating 4x6s in triangle and 4x8s outside it.
Stupid speed at 28s just under 120v 2p (possible with the lyen I've got)
or run 14s4p which is looking like a tidy long distance haul....
or sorry to digress in my case with my planned dual motor:
14s2p x 25amps bafang mid drive
14s2p x 60 amps 4065 hub which would be in its continuous rating of 2500w
I doubt you could top that with these new 14s hyperion chargers (if they had 7s single plug lipo cheap) or with the 8s ichargers that are also out
There's actually no such thing as a specifically defined charger like this, the voltage range on nearly all of them is adjustable so it just depends on what you specify at the factory when getting them made. 21S li-ion/lipo is also almost exactly the same voltage as the 24S lifepo4 (88.2 vs 88.8) so you can use the same chargers and these li-ion packs would be a direct drop in replacement for an old 24S lifepo4 one. So that's point G:John Bozi said:It also explains why there is a 21s charger which I was confused about.
pendragon8000 said:Back on topic, does anyone know if my brakes are frocked now that they leaked oil from the caliper? Still haven't sussed it out more.
Sorry Pend to go off your topic,Hyena said:There's actually no such thing as a specifically defined charger like this, the voltage range on nearly all of them is adjustable so it just depends on what you specify at the factory when getting them made. 21S li-ion/lipo is also almost exactly the same voltage as the 24S lifepo4 (88.2 vs 88.8) so you can use the same chargers and these li-ion packs would be a direct drop in replacement for an old 24S lifepo4 one. So that's point G:John Bozi said:It also explains why there is a 21s charger which I was confused about.![]()
Nah they are not close.John Bozi said:Do you by any chance have your phase wires bundled together with your brake fluid line? Because I had a couple of issues when up the mountain at high heat levels having my rear brake go not work as did when running cool. I was guessing I was heating the fluid.
Rix said:Don't know if I missed it, but did you find out what was going on with your leaky brake?
Thats a releifpendragon8000 said:Well the volume I put in looks the same as what came out. It was more of a flushing air bubbles and old fluid.
pendragon8000 said:Incase you hhaven't seen it yet, I've modded the h4065...
I've tested this attachment I've designed and created with my 3d printer. an impeller than goes on under the disc brake rotor. The colling effect was really significant, producing the cooling effect of the same difference from not drilled to drilled, as , drilled to drilled with the impeller. Essentially double the cooling effect, much like Justin's results on his 9c motor from a while back.
I'm selling them here:
https://www.endless-sphere.com/forums/viewtopic.php?f=31&t=68373
Here are the tests:
http://endless-sphere.com/forums/viewtopic.php?f=31&t=68373#p1030688
More test results to come soon.
That reminds me I have started work on a "wheelie mode" arduino controller and app but i have so many things going on , its on the back burner for now.detroito said:I would be poppin wheelies on that thing all day long with that motor lol
