@mr_transistor
Too lazy to write it all again, so i will post my e-mail that i sended to him 9.11.08 (dd/mm/yy):
"Hello there.
So i picked up my battery from customs Thursday, opened it at work Friday, fixed damaged charger cover with glue (most likely transport damage), checked voltage on batterypack (39,5V), putted it under artificial load (40V lightbulbs consisting together 180W load) on batterypack.
All and well till 37,75V and then voltage started to drop pretty fast.
When voltage dropped to 36,95V current was cut off (i take that BMS does it ?).
I assume that BMS does cut voltage too high (nominal voltage should be 36V ?).
I though that BMS was designed to cut power off somewhere around 32-33V ?
And it gets even better.
When i putted charger to load batterypack it went well.
But after sometime (around 45 minutes) when i went to check out the level of charging, the charger had fried it's own fuse (3A) and even the automatic fuse (10A) was down.
Checked voltage on batterypack and it was 39,5V.
Putted it under same artificial load as earlier, but this time it's voltage levels lowered much faster than before to the 36,95V where current was cut off again.
After changing the fuse on charger (i'm electrician), i tried to plug charger to the wall outlet and it blew it's fuse and voltage regulator and that 10A automatic fuse also went down as earlier."
His answer, next day:
"hi, friend
thanks for your messenger , we pack very well with the charger, i am sorry to hear the charger crust is broken ,i think it is broken on the way due to the battery is so heavy and press the charger crust broken. and but it is good inside if you work well .
please remmeber to use the BMS with the battery together, because the BMS protect the battery to use long time .
yes, the BMS will cut off if voltage too high , because the battery you order is 36v 20ah .
about the battery , BMS , charger , our factory proffesional all test 3 times before we shipped , all are great .
i ask our proffesioal , when you charge the battery ( if cut off due to the voltage), you could pull out the BMS , so it is easy to charge the battery fully .
when you use the battery , you must insert the BMS and use together to protect the battery .
i suggest you not use your 2A lead acid charger , because our charger only charge the LiFePO4 battery .
if also have any other question , let me know .
if it is ok , hope you will leave a feedback for me, i will do the same for you , thanks again and nice to do business with you
dave"
My answer:
"No, no you got it all wrong.
BMS cuts voltage when it is not supposed to.
When voltage is lowering from 39,5 volts to 36,95 it cuts it off.
If BMS cuts voltage off without getting to it's nominal voltage (36 volts), then it can't be alright."
His reply next day:
"Hi, friend
thanks for your fast reply , i ask our factory proffesional again , when you charge for the battery , it will cut off when the voltage is is lowering from 39,5 volts to 36,95 .
but if you use the battery and BMS together when Discharging , it is no problem .
so if you don't want to the BMS cut off when you charging, please remove the BMS to charging , then charge fully , you insert the BMS again to protect the battery when you use the battery.
if it is not good for you like that, how about you only pay the shipping cost , we send the other BMS to you for free again . or you return that BMS, and we resend the other BMS to you all for free to you , let me know your idea, thanks for your great understanding
dave"
I only did three test charges during this conversation.(not counting first charge to make sure it is full)
Initial charge went well. Voltage was after charge 39,5V.
After discharging it i was amazed how fast it went off.
Used my voltagemeter to see what voltage was after cutting off. It was that 36,95V.
After next charge, charger blow its fuse. I was like wtf, and replaced it and checked other components too.
(It still charged it full.)
And again during discharge it went off during 36,95V.
After next charge, it had blown its own fuse and most of the component on it's pcb.
Meh, had co-worker change all those component that were fried. (minus that big one, i take it is the transformer)
And it did again, when i plugged it in.
Was gonna mail him next day, but i sprained/injured my back and were in hospital for over a month.
I had somewhat forgotten the whole issue, but when i went back to work, (after being home after hospital for couple weeks)
i remembered it and mailed him:
"Hello there again.
Would like you to send me the new charger and BMS-unit.
Have been in hospital for over a month, would have contacted you earlier if i could have.
Friend of mine analyzed that charger and changed the most of the parts to the new ones.
He suggested that the transformer on the charger has been busted from the beginning.
And the BMS could be faulty for cutting off to early when discharging."
Waited for a week.
No answer.
Next mail i shoot to him:
"It seems that you won't like to send those items to me, so i'm gonna have to escalate this in to dispute in PayPal.
Have been hearing in forums that i weren't the only one who got a bad charger and second-hand Bms from you."
And after that Paypal couldn't/wouldn't do anything, i came here only to find that he had copied his Bms from Ping and other people having also problem with batterypack from him.
That's why i asked if anybody else had any problem's with him.
