Ladies and Gents..
I've been reading a lot and I'm about to order some stuff. I'm pretty confident that this setup will work, but I could be really wrong!. But since this is the first time I'm about to build a DIY longboard. Some criticism will be greatly appreciated!
Idea for a first build:
single engine 6s and 12s config.
-Generic longboard (still to decide, probably bought locally, at least something stiff with a lot of room for 90mm Flywheels)
-Caliber II trucks (bought locally)
-DIY mount for 63mm
-Turnigy 168KV 63mm SK3 brushless
- 2 Zippy 5000 30C 6s (seemed allright to me with a 30C discharge)
-DIY ESC 120A (dunno where to buy a VESC!)
-DIY Flywheels 90mm
-Generic Bearings (locally bought)
-Imax Battery charger (i'm not sure, this looked allright, so advice is appreciated!)
-Sprockets and belts, which I hope to be able to order at DIY or other supplier.
-Sweet reliable little 2.4 ghz DIY remote
6S
12S
Some explanation, I might be wrong though, please correct me, I played with excel to try get it right..
A is KV, B Max V is 6s,C Wheel diameter 90 mm, D theoretical top speed in KM/h. E gear ratio 2:1, F RPS (revs per second), G roll dist per R is distance per rotation of wheel, H RPM engine is theoretical max rpm's
So I would start with a 6s config, this will make a not too fast but rideable board. I could then double to a 12s (ESC and motor can handle this) and go faster and more acceleration. My idea would be that I can hand the "tame board" to my small nephew, or friend who has never long boarded before with a 6s configuration, but when I want to ride myself, the 12s configuration is put on. (Dr. Jackell and Mr. Hyde modes).
My doubts and questions:
-Is that 2:1 ratio realistic? Is DIY boards able to deliver such sprockets and belts, does that fit on a engine mount? What should I order?
-Should I go for a higher KV and different ratio?
-Is my Dr. Jackal and Mr. Hyde mode idea feasible?
-Where do I buy a VESC, should I or is the DIY ESC a good option too, that VESC sound really awesome, especially while the motor is senseless.
P.S. Here is my excel sheet, just fill out the KV, wheel diameter and all the other numbers appear
-DIY mount for 63mm
-DIY Flywheels 90mm
6S
12S
