sal_park
Hi Guys,
I had a bit of an adventure 2 days ago on the way to work - tried a new route and what appeared to be a big puddled turned out to be a flooded path - the water went about 1 1/2 foot deep so the front hub motor (250W bang-fang) was well and truly submerged. I used the motor all the way through the ~600 yard section and it was probably submerged/running for 1 1/2 minutes or so. Everything was fine on the rest of the journey, and again on the way home, although the motor was a little noisier than normal.
Next day on the way home from work (the bike had done around 7 miles since going through the flood) the motor cut out a few times It seemed to be if I'd not used the throttle for a short period that it would happen and would never cut out while I was using the throttle. It only did it a few times and at the end of the ride I could not provoke it into breaking.
I suspect it's the throttle control (thumb type) as the mechanical action of this was getting a bit stiff so I sprayed it with WD-40 a few weeks ago.
Also worthy of note - the controller and battery did not go underwater and I think the battery is fine as my lights (powered by the battery) were working fine while the motor was not.
Anyway, what do you think ? All comments welcome.
sal_park
sal_park
