IanFiTheDwarf
I’m back on my axial motor build again and have just received the laminations for the coils, so I now need to build some of the structure to support the coils.
Basically I need two discs which will be about 280mm diameter with holes milled in them to slot over either end of the coils then the whole assembly will slot into the tube of the motor housing and be screwed in place from outside with quite a lot of screws.
I was going to use aluminium about 8 mm thick but I am concerned about eddy currents being induced and heating everything up reducing efficiency. So now I am thinking about various plastics polycarbonate is the strongest non reinforced plastic I know of but I also thought about carbon fibre, glass fibre or Tufnell
Carbon fibre should be the strongest but the carbon is electrically conductive so might give problems with eddy currents also
Next strongest is glass fibre (FR-4) but from my experience it can delaminate when machined (but maybe that was just a poor grade cheap material)
Tufnell I have used quite a few times and it has always served me well but I have never thought of it as a modern high strength material
Do you thing the aluminium will be a problem and if so what would you suggest?
The cylindrical section and the two end plates of the motor will be aluminium.
Cheers
Ian
Cheers
Ian
