Hi there,
i am very new to the whole ebike game, but i came across an ampler stout ebike for free with a seemingly broken controller.
now that i have kompletely gutted the bike, i have realized that the motor behaves odd (so i think):
- the motor can manually (no esc or hall sensors connectred) spin efortless in one direction. the other direction is quite hard and feels like an electronic break
- when i put 5V / GND on the hall sensor, there are readings, but only in the "hard" to turn direction. the other free spinning direction does not show any readings.
since i am really new to motors like this and i have never hat one in my hands before, i am not sure if this is expected or not. but i am guessing its not.
What could be the problem here and how could i try to fix it without just buying a new one?
Thanks a lot for help!!
PS: its the same motor like here:
endless-sphere.com
endless-sphere.com
endless-sphere.com
Q100C CST 201RPM BMSBattery Hub Clutch Roller Spring Upgrade
When I tried to setup my Q100C CST with Grin's Phaserunner(PR), I quickly destroyed the stock freewheel clutch springs while dialing in the motor after doing the PR software's autotune. I think a lot of other people like this light rear hub motor, so I thought I'd post this info in case anyone...
endless-sphere.com
Factory changes for the Q100C .
One of the nice things about the "Cuties" is the ease one can swap different "cores" into one housing. It was with this in mind that I ordered a pair of "201"slow wind motors to replace the two 328 "fast winds" in my 2WD Rocky Mountain. Dropping the front Q100H 201 in place of the standard Q100...
endless-sphere.com
Cute Q100CST Smaller 42mm Flange Ver Open wt Vice Disc Rotor
I opened up my Cute 100 Q100CST to figure out the number of pole pairs so I could use it with the hall sensors properly with the ebikes.ca Phaserunner controller. This is the newer Black 42mm flange to flange version of this motor. There was a previous version of this out before this that was a...
endless-sphere.com
