michaelplogue
markcycle said:Regen is really all you need except when your stopped on a steep hill or if regen fails. The way I have it setup is if you just touch the rear brake pedal it turn on regen at 10%, then on the left handle bar I have a thumb throttle wired to the variable regen input. and that allows one to add as much regen as needed. The rear disc brake is so I meet DOT standards and as a backup. The regen in the Kelly controller works well for the rear brake. If I want to lock up the rear brake I can use full regen plus the rear disc brake.
Mark
One thing I've considered on my motorcycle conversion - The right pedal remains the same for mechanical braking. Since you no longer need to shift gears, I was thinking of connecting the left foot control to a throttle so it can be used to control the regen braking. Another option could be to use the left hand clutch lever and use it as the regen brake 'throttle.'
