Hi Mark:
I'm following your motor developments with interest. Congratulations on your sustained efforts, its really coming together.
I have a couple more questions about the motor as it applies to my application:
1. I'm continuing to develop my light tadpole trike design, and most likely will wind up at around 460lbs dry, lbs gvw. I plan to use 34-36 LiFePO4 cells of 80-90Ah, and the Kelly 120V/400A controller unless your own design, or something your recommend more highly, is available. This will give me 109-116 Volts nominal, up to 136 fresh off the charger (that level of surface charge, as I understand it, would last far less than a minute, but I have no experience with these batteries...) I'm using the swing arm, spring/damper unit and rear caliper/disc from a 2005 Yamaha YZ125. My Cd should be under .25, and it looks like I can keep the frontal area near 17 square feet. If I hit those targets, this thing could maybe touch 100mph with with your motor, (my calculations indicate it would take something like 29-36 horsepower to do that, depending on lots of assumptions and how I do the math.) My concern is really at the other end of the spectrum, though- the last 1/4 mile to my house is a 350' hill on public roads, and I need to climb it and have decent acceleration to make the trike usable. The swing arm will accommodate any 17 or 18 inch tire, and I'm shooting for the lowest weight and highest efficiency, (tall and skinny, like maybe even a front tire,) so what do you think would be a good compromise wheel/tire spec/size for this application? What would you guess (not holding you to it, just a ballpark) that a unit like that would weigh, including a lightweight rim, tire and YZ125 (245mm) brake disc? Put another way, what does your prototype weigh, and how would what I'm asking for compare with that?
2. Do you have a recommendation of the 602 v. 603 motor for the above application?
3. Cooling is going to be my big issue. This isn't really a question, because I don't need to figure it out right now, but I will follow your fan cooling developments, and if nobody gets there ahead of me, I'll probably be knocking on your door early next year about liquid cooling. I'm not at the construction stage now, and for the the first iteration I'll almost certainly be working out the various systems on an open-chassis tube-frame test mule, so the project isn't likely to be stalled for motor/controller cooling system development.
Of course, anything else you'd like to know or think I should know is most appreciated.
Thanks, and keep up the great work!
Tom Alvary
Just a Tinkerer
White Plains, NY
