Mounting Gearbox & Motor Aluminum Frame - Weld? Bond?
For recumbents, how about a TerraCycle Easy Reacher Rack? URL: http://www.terracycle.com/
That's what I used for my mount, and it fits beautifully: http://gregg.berkholtz.net/wiki/doku.php?id=recchetta
There is an alternative to TIG welding when working with non-magnetic metals.
http://durafix.com/
I've gotten some of these rods myself for my build (haven't tried it yet), but looks relatively easy to use. Just needs a torch.
http://video.google.com/videosearch?hl=en&&channel=s&rls=org.mozilla:en-US:eek:fficial&hs=zse&q=durafix&um=1&ie=UTF-8&sa=X&oi=video_result_group&resnum=4&ct=title#
We've used that stuff here before for some cracked aluminum fairing stays. I've said it before- it can work and work well if you prep correctly!
I actually had used alumiweld brazing sticks on different portions of my project and it seems quite sturdy. The one big issue I had was with putting together multiple pieces. As I would heat up one area the heat traveled quickly to the other side remelting my previous work. Due to the smaller nature of the part (motor mount) I was unable to keep the work clamped as I added new pieces of aluminum, so in the end I recut the aluminum and just tapped the aluminum running 8/32 bolts through sandwiching some jbweld inbetween and the piece turned out more than strong enough for my motor.
