rayebiker said:Can someone please post a video of the AM1000 in action. I can't find any YouTube videos of the bike being ridden, only assembled. About to pull the trigger. I do all mountain riding and am hard on my bikes. Want some confirmation it will hold up and rides well. Planning on the lyrik fork. Decided tprobably skip the EX1 in favor of the xt driveline.
Hillhater said:Does anyone do stress analysis or stress tests on these new frames for integrated motors ?
The motor mount/bottom bracket area visually looks weak and flexible compared to a conventional diamond frame bottom bracket with 3 main tubes joining the bracket tube.
I would expect flexing possible cracking after a few months of off road use.
JMHO .!
JMHO .!
Ender2000 said:P.S. Does the battery stick out on the sides or is it flush with the frame?
Ender2000 said:Does anyone else feel a bit of a lurch to one side when the motor is engaged?
TOLM said:Ender2000 said:Does anyone else feel a bit of a lurch to one side when the motor is engaged?
Welcome to full suspension e-bikes (( rear triangle is moving. Effect is less pronounced with hardtails.
Popcorn popping sound sounds like a rear derailleur adjustment issue to me. There are two ways to proceed. Option 1. Go youtube and check the video on rear derailleur adjustment from Park Tool guy. It is like 16 min long and pretty good. You will learn how to use the h , l screws and the indexing thing. Option 2 is bike shop. Much easier but will cost you something.Ender2000 said:TOLM said:Ender2000 said:Does anyone else feel a bit of a lurch to one side when the motor is engaged?
Ah, yes, I am new to this. I'm having some shifting issues and was wondering if this would be a contributing factor. I'm upgrading to an ex1 derailleur this week in hopes of less popcorn popping when I go outside of my middle gears.
TOLM said:Popcorn popping sound sounds like a rear derailleur adjustment issue to me. There are two ways to proceed. Option 1. Go youtube and check the video on rear derailleur adjustment from Park Tool guy. It is like 16 min long and pretty good. You will learn how to use the h , l screws and the indexing thing. Option 2 is bike shop. Much easier but will cost you something.Ender2000 said:TOLM said:Ender2000 said:Does anyone else feel a bit of a lurch to one side when the motor is engaged?
Ender2000 said:TOLM said:Popcorn popping sound sounds like a rear derailleur adjustment issue to me. There are two ways to proceed. Option 1. Go youtube and check the video on rear derailleur adjustment from Park Tool guy. It is like 16 min long and pretty good. You will learn how to use the h , l screws and the indexing thing. Option 2 is bike shop. Much easier but will cost you something.Ender2000 said:TOLM said:Welcome to full suspension e-bikes (( rear triangle is moving. Effect is less pronounced with hardtails.
I agree. I did watch a similar video, but I ultimately elected to have my $140 EX1 derailleur installed by the bike guy for $30. I wanted it to be done right on the initial setup, even if I have to adjust it later. So far, it's be an INCREDIBLE upgrade. I won't say definitively that all my shifting problems are gone, because I've been hesitant to really push the bike to its limits after recent issues, but after about 20 miles playing with up to level four on the low gears for off roading, no problems. Haven't tried for high speeds.
Incidentally, I might as well mention I elected to get the EX1 derailleur and shifter, but NOT the $350 cassette. I used a $29 sunrace cassette from shimano that is also 8 cogs, and the main difference (aside from alloy quality) is that it jumps from 11t to 40t in 8 gears as opposed to the EX1 cassette's 48t lowest. I admit that that's not quite as dramatic, but with the g510 I can climb pretty much anything I want to climb with that cassette and if I break it it's only 29 bucks to replace, which wouldn't make me scream and cuss like the SRAM.
Anyhow, it works really well with the EX1 system so far, so I thought I'd share my experience.
DaninSpain said:nataS@phnet.fi said:DaninSpain said:Can anyone offer any help / advice? A step by step would be really nice, or if anyone knows of a YouTube video for changing pads on the MT5, which incidentally is different to the MT7, can you post the link.
Sorry for being such a dumb-ass re bike maintenance![]()
It's not rocket science luckily so even i manage to do it
Take the wheel off. Take a look at the calibers, press them full open so maximum space is available. The pads are connected by magnets so just press first one side and slide the pad down. Then another one with same method. I also tried to find video about it but couldn't find so had to just try. But it's really easy and quick job.
Thanks NataS![]()
As it happens, I did exactly that earlier today and worked it out as I went along.
I removed the pads, cleaned with degreaser heated the up with a blowtorch to burn off the oil, then sanded them down repeated the whole thing. Took off the disk, soaked it petrol and gave it a good old scrub then refitted everything, looked down and found a washer![]()
I couldn't work out from which side it came so I tried both and decided on the disk side.
The brakes were binding a bit, so I loosened the whole brake unit, applied the brake then tightened it. Hey presto no more binding (I'm sure all the experienced bikers are pissing themselves laughing at the newbie:lol: :lol: :lol: )
Tried it out and all back to normal.
It's actually not as complicated as I thought this bike maintenance:lol:
