Deafcat
I've got the short Miranda cranks (8mm offset) as well and they are a huge improvement. Better stance less Q-factor, better ground clearance, must have if your frame/heels will clear appropriately.
Tjeska said:Stanleybb50 said:OH and while we're at it, I remember reading about shorter cranks. I'm sure I could find the answer from a search in about 2 minutes, but if someone feels like calling that out as well, it would be greatly appreciated!
Thanks!
Shorter cranks: 150 mm Delta
REF NUMBER: PD11IBT17CA700001541
Miranda bikes
https://mirandabikeparts.com
Let me know what you think of them, if I get my bike its possible I will order a set to.
arrowrod said:I have received my Frey AM1000. Replaced the tires with Schwalbe Moto-x 27.5x2.8. Failed at making them tubeless. The rims have a "slit" (where the rim is joined in a hoop) in the rim that leak. Frey insisted that their rims can't be made tubeless. Put a 53 tooth chainring on. Changed the handlebars and put an extended stem on.
I chug along at 25 mph (in Florida), with a smile on my face.
The battery charger has a fan, which charges in a couple of hours. It says its 2 amps.
I have a 52v battery.
Yellow...
FlyingFinn said:My FAT1000 was shipped on Friday. Anyone have had their bike shipped to Europe? Any estimates?
Tjeska said:Can anyone tell me which thread the 12x148 rear axle has?
I would like to tow a child trailer occasionally, and would buy a other axle for this.
"This is NOT an axle for attaching trailers or trainers"Hardcore said:Tjeska said:I would like to tow a child trailer occasionally, and would buy a other axle for this.
This axle has a 1.5 mm thread pitch. I used this bolt on
john61ct said:"This is NOT an axle for attaching trailers or trainers"Hardcore said:Tjeska said:I would like to tow a child trailer occasionally, and would buy a other axle for this.
Hardcore said:Tjeska said:Can anyone tell me which thread the 12x148 rear axle has?
This axle has a 1.5 mm thread pitch. I used this bolt on instead of the quick release:
https://robertaxleproject.com/product/lightning-bolt-on-axle-rear-12-mm-x-178-mm-x-1-5-thread/
Tjeska said:Does anyone has tried to run tubeless with the stock rims?
