speedsix said:
I am really astonished about your post... If you found such bad quality it sounds like really dangerous for our safe..
I just ordered two FREY fat 1000 with four batteries 48v 21ah.
If I had before those information probably I did not buy the second batteries....
I think that FREY must guarantee the clients with a hight and safe standard and quality, not only for bilkes but also for batteries especially because those are sealed and sensitive parts!!
Hi,
i think it is not Freys fault.
it is a typical "Chinese problem".
there are 2 good products to combine:
- Reention Dorado MaxID battery case for 80 cells, a good case i think. good space between the cells and the cages are perfect. also enough room for a small BMS
- LG 18650 MJ1 cell (or the now used Samsung cell). With a CDR of 10 amps it runs best at 5amps. this cell runs forever if only charged to 90% and running at a normal heat.
lets say we need 30 amps (Bafang Ultra). so 5x6= 30amps, with 78 cells you have a perfect match using 14s6p.
everything is perfect or ?
but what happens: the manufacturer (not Frey i think) builds this battery like any other battery - only difference: specified cells. this manufacturer uses cheaper nickel plated steel strips so he can save $8 per battery. and the manufacturer uses weak/less serial connections that are really needed. so what happens ? last cell before and after each of the 2 strip serial connection gets hot/warmer (all current goes through). these last cells will age faster. and therefore all cells in this cell block will age faster. and therefore the whole battery will age faster.
2 good products become a disaster in that way. and finally you have a 10 amps continous/ 20 amps peak battery - which i would rate this battery.
to illustrate it, i think 7mm strips were used (taken from another thread):
but hey you can check it: my new battery (own built) has a voltage drop of around 2 volts running at 30 amps (90% charged = 4.1volts per cell group - i never charge up to 4.2 volts. and 30 amps = which is the original max setting of Bafang Ultra controller). i have higher current cells in 5p. but anyways with 6p the current is only 5 amps per cell instead of 6 amps per cell for my 5p battery. on the other hand internal resistance of the Samsung and LG cells used by Frey is a little higher and also the voltage drop. anyways lets say a voltage drop of 4 volts should be the maximum for the 48 volts 13s6p battery (sport mode, constant engagement, full power= max watts for a longer distance). now i am interested what you will messure with your 48v battery (what your display will show as min voltage) ?
anyways I did not care about it in the past and had a lot fun with my 48 volts battery !
Sometimes it's better not to know everything. :lol:
and perhaps now they build better batteries ! (with better serial connections, my battery was very old, 3 years i think)
perhaps someone with a newer 48v battery can give some information about his voltage drop...
