Kormyr said:Saymon Vasilman said:I asked the manufacturer Frey about the new CANbus motors. They said that in the near future all ULTRA motors will be with CANbus. This will not allow programming the motor or using the EGGrider.![]()
Speaking of EggRider, I have 1 on my EX with dual battery, and remaining % is completely off.
For example:
1) I start with 100%, then after 5min of moderate ride it shows 89%, when I turn it off and on again it goes back to 96%.
2) After a 20km ride it goes all the way from 100% to 0%, then 60-70% after rebooting
I did not do any modification on the settings, is there a place where I can set the battery capacity?
Nevermind I found the setting, just needed to read the manual.
In the display option you can enter the Ah (28 for dual battery), then % is ok.
I have another question though. I had a "display overvoltage" message on my EggRider.
I found this post in this topic that seem to give an explanation on this issue: https://endless-sphere.com/forums/viewtopic.php?p=1589744#p1589744
If I understand correctly, using EggRider with the stock Frey dual battery configuration could cause damage to the EggRider display.
I'm not an expert so can someone explain if there is something that could be done to prevent damages to the display, without voiding any warranty?
