Hello everyone,
I'm a long-time lurker and have finally decided to build something small that I can use to roam a parcel I have in a remote location. It has some steep hills to traverse so I opted for a system with higher current. My electronics knowledge is extensive, but not with high-amp DC circuits. At one point in my history I designed PLL transmitters/receivers kits up to 450mhz using the PIC microcontroller among other things.
The Donor Is a Baja Minibike: http://www.bajamotorsportsonline.com/product_info.php?cPath=3&products_id=97 I'm planning on a 4.5:1 gear ratio to the wheel which has a 54" circumference. I'm aiming for good torque and 30 mph.
The Kit is this: http://www.cloudelectric.com/product_p/pk-el-m909-a300-axe.htm
For starters I'm planning on 12 3.2v 40ah LiFePo4 batteries wired for 36 volts.
I have some various other things coming in like a Cycle Analyst and Data Logger from Spark Fun.
Now for my endless stream of questions....
I'm tossed between using a Balance Charger like the Hyperion EOS 0601I Duo or building a BMS like the one designed here. It appears the danger of not using a BMS is when you wire the batteries in parallel. This is not my case however and should easily detect if an open occurs since my batteries will be wired in series. Plus the fact that the current version of the BMS here is in flux and entering its final stages of development and will not be available for planned completion date in a few weeks for rough trials.
Next is a tough one... can I charge my batteries while using them? Anything special I need to add to do this? I've yet to see a hybrid system schematic but it is possible that I'll tow a generator on very long trips to charge the batteries. My first thought was to get another bank and replace but that seems so inefficient.
Now the motor bracket. Most brackets I've seen are just a plate of steel welded to the frame perpendicular to the motor's drive shaft. Is that enough? It seems there would be lateral forces that need to be dealt with in the brackets design.
FINALLY!! Last question! I promise!!! (for now
) Many in the Baja Gas Community applied a Comit Torque Converter to increase low-end torque and high-end speed. This is an amazing device that incorporates a clutch and variable drive mechanism that increases in diameter as rpm increases... kinda like an automatic transmission. I can see this applied to my project since it 'should' decrease 'stalled' amps and give me the benefits of the gas application. Thoughts?
That's all the major questions for now.
Thanks in advance,
Bit
Thanks in advance,
Bit
