ridethelightning said:
iv powered up my max e, and gone through the first steps to getting it running. all straight foward, except that the magura throttle seems to be on full if connected. i had to disconnect it to stop the motor.
did you have anything like this going on?
perhaps the throttle pot needs adjusting?
apart from that, iv got to say i was very impressed to the smoothe sound of the cromotor
i had the same problem. it was not full throttle but about 20%. keep in mind with torque mode the wheel will always spin to max rpm at any kind of throttle input.
For setup i put the bike on some wood pieces to keep the wheel spinning free off the ground (you anyway should do this when first setup the controller over "autodetect"; be careful because the pedals move if motor turns backward).
Go fast in controller calibration menu to "thr limits". In this menu the motor will stop. Set the lower and upper "bars" to workable values. than go in "thr linear" menu to calibrate throttle.
After this my throttle worked, but i noticed voltage-range only was between 1,6-3,5V or so, and not 0-4,5V like it should be with 5k pot throttle.
I was riding long time with this settings. When i set up my variable e-brake nothing more was working, because e-brake and throttle start to interfere.
I found out my GND wire was dead (the failure was at connector on display side). Check these wires first!. After the fix all worked well and now both e-brake and throttle range is like it should be
also important: if your throttle puts out more than 4,5V at full , controller will show a failure. If this happens, you have to solder a resistor in the +5V wire going to your throttle to lower voltage (i would say about 0,5k - 1k ohm should work).
yeah the silence is a real pleasure. you ride like a phantom
(a bell is essential to warn pedestrians)
