I just got done modding my controller to handle more voltage, I put in 975 ohms for the 82V hot voltage I have. Everything was working fine I put a few miles on the bike, then I was leaving a friends house and there was no throttle. Totally nothing. Fuse is not blown. I put a different throttle on and that one doesnt work either. Before I crack open the controller, could the Hall sensor be bad? If so how do I test it without taking the motor off.
Symptoms:
IF the controller is powered on the motor shutters really bad when I am pedaling.
IF the controller is off the motor is smooth up to about 8mph pedalling, but if I go higher then 9mph the motor starts to shutter.
I remember running out of juice one day earlier this year, and had to pedal all the way back, the motor did not shutter like this at all.
I'm kind of puzzled becuase all I did was ad in 3.3V more voltage to the config, and change out the power resistors from 870 to 975 total.
Symptoms:
