Thought I'd start a build thread. This is from the perspective of a complete novice. I have basic tools (please don't cringe if I use them NOT for their intended purpose, but still get the job done 8) ), I have ZERO electrical skills and a tight budget.
I had a vague idea, found this site and the idea flowered, thanks to advice and input from guys on here.
I CAN ride a board though 8)
I have a pintail longboard tucked away. The trucks were taken from an old eboard that had died a death, not for any other reason than they carve and ride beautifully with the big wheels on them. This, along with the fact that I re sprayed an electrical bolt on the bottom last summer goes to show that it was meant to be, as I have only decided to do this recently
This has an advantage that the rear truck has a bracket welded on with 4 holes that a mount can be bolted on. (Potentially, there are two mounts, so I could do a dual setup later down the line 8) )
I have ordered (arrived today) a turnigy 236kv motor, a red brick 120a esc, a wii nunchuck, wii chuck and arduino, two zippy flightmax 5000 20c.
Still waiting on the motor pulley
I am not 100% sure HOW they fit together, i just know that they will from reading up.
The old motor mount is for a brushed 12v 100w motor that coughs and farts when an adult stands on it, so a new mount is needed to enable fitting a stronger motor
****WARNING***** any engineers, users of CNC lathes, or anyone with metalwork skills, look away now
I work in an opticians. When I was looking busy ordering the parts, i mean working, I was racking my brains trying to think where I could get a motor mount made.
Honestly, I say it was meant to be, but one of the guys asked me if they should throw out an old Polaroid demo unit. A unit made of aluminium!
I, ahem, helped put it in the bin. I like this because the cross section is a sheet of aluminium with a reinforcing bar along the edge to (hopefully) keep rigidity (Al-u-min-yum over here where we speak properly
I cut a 'sheet' out of the display unit with a jigsaw and started to roughly shape it using the old mount as a template and drill a hole for the truck
I then used a file to finish and shape
I have kept the other side of the mount as is for now, as I did not have the motor yesterday and am still waiting in the pulley to measure up and shape, hence the poor clearance under the board for now. The wheel has 60 teeth running a 15mm belt already, so i went for a motor pulley of 26 teeth from belting online, who have great service and fixed a screwed up order for me. I used a spreadsheet I found online to work out this should do 18-19mph? I would have used different gearing, but the wheelside pulley seems fairly fixed and I may as well use what's there anyway
The result for now is
Note the bottom cross section that is kind of a thick bar that I am hoping will stop the mount flexing during use. I am really pleased with this. I have never worked with metal before and it took a while.
Last night, I was tearing out hair with the arduino. Still not got it working
This thread may progress slowly, as I only tend to get one day a week to play with this project.
Please. Any mistakes I have made, or potential probs you spot, let me know before I finish the project, rather than let me find out the hard way!
