And then the question arose, what to charge this miracle with... I tried many chargers, and I'm not looking for simple ways, I chose a super-tricky charger with a large number of charging modes, 238 settings items, the ability to create a bunch of files in the XML extension and load them into the charger as presets, via Wi-Fi, the charger has its own web interface, login via IP address 192.168.4.1.
That is a lot of battery and weight in the back. It won't do the handling of the scooter any good. If it rides terrible this way, you could consider placing the battery box in the middle on the foot board and only use the foot pegs.
Yes, you are right, but I did it on purpose, there have already been cases in my life when the steering column was torn off, I have no time to weld it with an additional steel plate.
But in general, the weight imbalance is only at the start, then I do not notice it at all. Moreover, before this I carried a passenger of 68 kg. But the traction has dropped, the controller does not pull, I will replace it ...
The drop is very small, I only drove it once, I don't have time to test it yet, the BMS wrote: 2200W 32A.
I drove uphill at most. The charge was 68V, I drove uphill - downhill, 10km the charge was 66.5...67V restored.
I bought the same FNIRSI HRM-10 IR tester for building my 22S 2P battery with Gotian 32140 cells (with copper tabs). Where did you get the battery holder to fit 32140 cells? Mine is too short and fit only up to 18650 or 21700 cells, not 32140.
