FZBob said:Ehead said:I'm still fiddling around with the spacing on the main chain rings. Here is the rebel gear mounted and the Morezone bag from Amazon that fits the 4s 8000 fairly well. It is the small size and is a very tight fit with foam around the battery which is good. I couldn't use the box I had for the battery.I don't want any movement inside the bag. Magura Twist Grip tomorrow, shifters and tires Friday.
Just FYI,I had to cut a bit off the front derailleur so it wouldn't hit the motor chain when shifting into high gear...
Let us know what you think of the Magura. I've heard they are nice, but expensive.
Ah..I was just mumbling to myself I have to cut the lower area of the front derailleur. I may just go with 22t alone. The spacing on my bike chain rings are really close so I'll have to address this issue. I cut some large washers in half to space the Rebel ring but its not enough. If I flip the rebel around it gives me the gap but seems to hit the main chain. My crank arm is stopping me from spacing anymore. To be expected. trial and error. Not a big deal. I'll know more when I get the shifters.
Yes the Magura is 55 but the Domino is 90. So I bought 2 tires and the Magura instead of just the Domino. I hope I won't have the dead spot in the beginning of the throttle.
