I thought you guys might be interested in my RC Mid Drive conversion. I ride frequently in the hills, and I wanted to try just a bit of climbing assist without changing the character of the bike. I ran a Cyclone on and off about 7 years ago, but the benefit to downside ratio was not there, so i shelved it.
https://endless-sphere.com/forums/viewtopic.php?f=3&t=28621&p=412252&hilit=reign+cyclone#p412252
I did determine that about 250 watts of assist was a good balance between power and battery capacity.
I had been interested in RC motors since then, and last spring came across the Turnigy 125KV skateboard motor.
With 10:1 reduction, this motor could meet my performance criteria. I laid out a few gearboxes in Autocad (I’m an old Mechanical Engineer), but then determined that I could do it with #25 chain and 9T and 90T sprocket from electricscooterparts. The pics show a few different drive configurations I tried.
I have been riding the bike hard for the last 3 months - 250 miles and 25,000 feet climb - and I really like it. Everything has been reliable, and I have not snapped any chains at up to 470 watts. The chain has been stretching slightly, but if I need to replace a couple of chains a year that’s OK. The VESC torque control is far superior to the old Cyclone RPM control, making pedaling under power much more fluid and less obtrusive.
The bike is a ’08 Giant Reign with a big fork, really nice shock, wide rims and a 170mm dropper post. It rips downhill! It weighs 33.4lb without the motor, and under 38 with motor and one 4S 5800 pack. (the old cyclone system added 12lb!). This is good for a VERY PLEASANT assist on a 13 mile, 1250 foot climb, aggressive dirt ride with a friend who is 20 years younger, and a natural athlete. I am able to stay ahead of him on the downhills without motor, which means that the bike’s character is intact!
Edit 6-14-2019: Note that this system is a low power, light weight assist ASSIST. It is not intended or designed as a stand alone (no pedaling) drive. The motor, running at low RPM, is under powered for stand alone use. The drive system is too light to handle a big power increase.
