My website down?
Missouri
Can you guys confirm or deny that my website is down? I can't access it right now. That would be a huge bummer.
Pings ok, but I can't access via www or ip in browser.
http://74.208.59.250/
differs from holmeshobbies
208.54.152.33
neither open in browser
Hope it is a hosting issue and not hacker related. Got this email
[08-Sep-2009 10:32:50] (shop: 08-Sep-2009 10:32:50) SQL error:
Site : http://holmeshobbies.com
Remote IP : xxxxxxxxxxxx
Logged as :
SQL query : DELETE FROM xcart_sessions_data WHERE expiry < '1252420369'
Error code : 1064
Description : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '/holmesho_xcart/xcart_sessions_data EXTENDED' at line 1
Request URI: /home.php
Backtrace:
/home/holmesho/public_html/include/func/func.db.php:180
/home/holmesho/public_html/include/func/func.db.php:106
/home/holmesho/public_html/include/sessions.php:299
/home/holmesho/public_html/include/sessions.php:139
/home/holmesho/public_html/init.php:437
/home/holmesho/public_html/auth.php:44
/home/holmesho/public_html/home.php:38
ja. Oy vey.
Earlier, it showed a number of xcart errors along with the page display.
Code:
INVALID SQL: 145 : Table './holmesho_xcart/xcart_sessions_data' is marked as crashed and should
be repaired SQL QUERY FAILURE:SELECT COUNT(*) FROM xcart_sessions_data WHERE
sessid='cda39f4da0b81987ec56d4492ecd3fea' INVALID SQL: 145 : Table
'./holmesho_xcart/xcart_sessions_data' is marked as crashed and should be repaired SQL QUERY
FAILURE:SELECT sessid FROM xcart_sessions_data WHERE expiry < '1252423483' INVALID SQL: 145 :
Table './holmesho_xcart/xcart_sessions_data' is marked as crashed and should be repaired SQL
QUERY FAILURE:SELECT * FROM xcart_sessions_data WHERE sessid='cda39f4da0b81987ec56d4492ecd3fea'
be repaired SQL QUERY FAILURE:REPLACE INTO xcart_sessions_data (sessid, start, expiry, data)
VALUES('cda39f4da0b81987ec56d4492ecd3fea', '1252423483', '1252427083',
'a:1:{s:17:\"_saved_session_fg\";s:32:\"848c442f8cb4f2ac77060ba6514cf512\";}') Warning: Cannot
modify header information - headers already sent by (output started at
/home/holmesho/public_html/include/func/func.db.php:195) in
/home/holmesho/public_html/include/func/func.core.php on line 1591 INVALID SQL: 145 : Table
FAILURE:UPDATE xcart_sessions_data SET
data='a:6:{s:17:\"_saved_session_fg\";s:32:\"848c442f8cb4f2ac77060ba6514cf512\";s:11:\"editor_m
ode\";s:0:\"\";s:8:\"is_robot\";s:1:\"N\";s:5:\"robot\";s:0:\"\";s:11:\"is_location\";s:0:\"\";
s:9:\"adaptives\";a:1:{s:14:\"is_first_start\";s:1:\"Y\";}}' WHERE
data='a:7:{s:17:\"_saved_session_fg\";s:32:\"848c442f8cb4f2ac77060ba6514cf512\";s:11:\"editor_m
s:22:\"antibot_validation_val\";a:4:{s:13:\"on_contact_us\";a:2:{s:4:\"code\";s:5:\"54554\";s:4
:\"used\";s:1:\"N\";}
s:15:\"on_registration\";a:2:{s:4:\"code\";s:5:\"73134\";s:4:\"used\";s:1:\"N\";}
s:8:\"on_login\";a:2:{s:4:\"code\";s:5:\"36479\";s:4:\"used\";s:1:\"N\";}
s:10:\"on_reviews\";a:2:{s:4:\"code\";s:5:\"59536\";s:4:\"used\";s:1:\"N\";}}}' WHERE
data='a:25:{s:17:\"_saved_session_fg\";s:32:\"848c442f8cb4f2ac77060ba6514cf512\";s:11:\"editor_
mode\";s:0:\"\";s:8:\"is_robot\";s:1:\"N\";s:5:\"robot\";s:0:\"\";s:11:\"is_location\";s:0:\"\"
;s:9:\"adaptives\";a:1:{s:14:\"is_first_start\";s:1:\"Y\";}
s:11:\"logout_user\";s:0:\"\";s:26:\"session_failed_transaction\";s:0:\"\";s:16:\"add_to_cart_t
ime\";s:0:\"\";s:17:\"always_allow_shop\";s:0:\"\";s:11:\"search_data\";s:0:\"\";s:16:\"current
_url_page\";s:39:\"http://holmeshobbies.com/home.php?cat=3
\";s:12:\"current_date\";i:1252423524;s:19:\"session_create_date\";i:1252423524;s:4:\"wlid\";s:
0:\"\";s:10:\"js_enabled\";s:1:\"Y\";s:11:\"top_message\";s:0:\"\";s:15:\"referer_session\";s:1
86:\"
http://www.google.com/search?hl=en&as_q=holmes+hobbies&as_epq=&as_oq=&as_eq=&num=10&lr=
&as_filetype=&ft=i&as_sitesearch=&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=
images\";s:5:\"login\";s:0:\"\";s:10:\"login_type\";s:0:\"\";s:11:\"identifiers\";a:0:{}
s:6:\"logged\";s:0:\"\";s:14:\"remember_login\";b:0;s:13:\"remember_data\";s:0:\"\";}' WHERE
I cleared one of the php files, and that got rid of the errors. Database looks to be intact and unmolested.
Whew, that was scary. I was hoping that I didn't have to throw money at it.
